apt-get upgrade breaks working player.
Hello.
PI 3B
AMP2
clean install. library works and pandora works.
apt-get update && apt-get upgrade.
reboot
no sound.
The following packages will be upgraded:
dhcpcd5 e2fslibs e2fsprogs firmware-ralink libblas-common libblas3 libcairo2 libcomerr2 libdrm2 libfreetype6 liblapack3 liborc-0.4-0
libpam-modules libpam-modules-bin libpam-runtime libpam0g libpango-1.0-0 libpangocairo-1.0-0 libpangoft2-1.0-0 libpixman-1-0 libsdl1.2debian
libss2 libva1 x11-common
volumio@audiobox:~$ sudo systemctl status mpd.service -l
● mpd.service - Music Player Daemon
Loaded: loaded (/lib/systemd/system/mpd.service; enabled)
Active: failed (Result: exit-code) since Fri 2019-07-19 11:35:09 UTC; 1min 21s ago
Docs: man:mpd(1)
man:mpd.conf(5)
Process: 1325 ExecStart=/usr/bin/mpd --no-daemon (code=exited, status=127)
Main PID: 1325 (code=exited, status=127)
Jul 19 11:35:08 audiobox mpd[1325]: /usr/bin/mpd: error while loading shared libraries: libbcm_host.so: cannot open shared object file: No such file or directory
Jul 19 11:35:09 audiobox systemd[1]: mpd.service: main process exited, code=exited, status=127/n/a
Jul 19 11:35:09 audiobox systemd[1]: Failed to start Music Player Daemon.
Jul 19 11:35:09 audiobox systemd[1]: Unit mpd.service entered failed state.
Exactly as expected if you check the Volumio FAQ: volumio.github.io/docs/FAQs/Upd … nance.html
Volumio is a tailored distribution, not just some software running alongside your normal OS. Manually updating with apt-get messes with that.
