nikkon
1
Hi all,
i’m new with volimio and i have this issue :
root@volumio:~# apt-get update
Hit archive.raspbian.org jessie InRelease
Get:1 archive.raspbian.org jessie/main Sources [7745 kB]
Get:2 archive.raspbian.org jessie/contrib Sources [64.5 kB]
Get:3 archive.raspbian.org jessie/non-free Sources [113 kB]
Get:4 archive.raspbian.org jessie/main armhf Packages [8981 kB]
Get:5 archive.raspbian.org jessie/contrib armhf Packages [37.5 kB]
Get:6 archive.raspbian.org jessie/non-free armhf Packages [70.3 kB]
Ign archive.raspbian.org jessie/contrib Translation-en
Ign archive.raspbian.org jessie/main Translation-en
Ign archive.raspbian.org jessie/non-free Translation-en
Fetched 9266 kB in 43s (211 kB/s)
W: Failed to fetch archive.raspbian.org/raspbian/di … ce/Sources Hash Sum mismatch
W: Failed to fetch archive.raspbian.org/raspbian/di … f/Packages Hash Sum mismatch
E: Some index files failed to download. They have been ignored, or old ones used instead.
Any clue?
Thank you
Saiyato
2
Possibly a rights problem, try:
sudo rm -rf /var/lib/apt/lists/*
And then update again, this has nothing to do with Volumio, just linux ![:wink: :wink:](/images/emoji/apple/wink.png?v=9)
nikkon
3
Get:1 archive.raspbian.org jessie InRelease [14.9 kB]
Get:2 archive.raspbian.org jessie/main Sources [7745 kB]
Get:3 archive.raspbian.org jessie/contrib Sources [64.5 kB]
Get:4 archive.raspbian.org jessie/non-free Sources [113 kB]
Get:5 archive.raspbian.org jessie/main armhf Packages [8982 kB]
Get:6 archive.raspbian.org jessie/contrib armhf Packages [37.5 kB]
Get:7 archive.raspbian.org jessie/non-free armhf Packages [70.3 kB]
Fetched 17.0 MB in 43s (396 kB/s)
same issue
nikkon
4
I know is Linux
still the repo seems broken even if it works when i wget.
Saiyato
5
Did you add new sources? Because in my experiments I have never seen this. ![:unamused: :unamused:](/images/emoji/apple/unamused.png?v=9)
nikkon
6
nope. it’s a fresh install.
Saiyato
7
Does the same happen when you try sudo-ing it using the volumio user?
This is what I get, which is weird, since the public key error never happened before on this pi… oh well… might be something entirely different.
volumio@volumio-v978:~$ sudo apt-get update
Get:1 http://archive.raspbian.org jessie InRelease [14.9 kB]
Get:2 http://archive.raspbian.org jessie/main Sources [7745 kB]
Get:3 http://http.debian.net jessie-backports InRelease [166 kB]
Ign http://http.debian.net jessie-backports InRelease
Get:4 http://http.debian.net jessie-backports/main Translation-en [475 kB]
Get:5 http://http.debian.net jessie-backports/main armhf Packages [669 kB]
Get:6 http://archive.raspbian.org jessie/contrib Sources [64.5 kB]
Get:7 http://archive.raspbian.org jessie/non-free Sources [113 kB]
Get:8 http://archive.raspbian.org jessie/main armhf Packages [8981 kB]
Get:9 http://archive.raspbian.org jessie/contrib armhf Packages [37.5 kB]
Get:10 http://archive.raspbian.org jessie/non-free armhf Packages [70.3 kB]
Ign http://archive.raspbian.org jessie/contrib Translation-en
Ign http://archive.raspbian.org jessie/main Translation-en
Ign http://archive.raspbian.org jessie/non-free Translation-en
Fetched 18.3 MB in 1min 20s (227 kB/s)
Reading package lists... Done
W: GPG error: http://http.debian.net jessie-backports InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 8B48AD6246925553 NO_PUBKEY 7638D0442B90D010
nikkon
8
yes i have the same result.
