Hi All,
I just set up an RP4 that feeds into a preamp with a DAC. Spotify Connect works great. I can’t get Airplay to work. I’d like to be able to use an Apple Music subscription and Podcasts via Airplay.
The RP4 appears as an eligible device for Airplay, successfully connects but outputs no sound.
Apologies if this is asked a lot. I did a good faith scan of past topics and I couldn’t find an answer w/r/t troubleshooting Airplay.
This is a community forum, for support specifically with myVolumio, email techsupport at volumio dot org!
