Apple Music: Force airplay 1 to get lossless?
I’m using Apple Music as music source, I have a family subscription and I have to use it.
I read that with “Airplay2” the quality is LOSSY but by forcing “Ariplay1” (no multi room etc) the quality should be LOSSLEES 16/44.
Is it true? Is there a way to force Volume to use Airplay1?
THANKS
I’m interested how to force AirPlay 1 too and disable software volume controls.
For example Ropiee OS have options like that.
