Hi all,
i have the dac in object with raspberry pi 3 b.
I’ve installed volumio ver. 2.555 (the last one) for that dac, but it doesn’t work properly.
If i select Aoide dac ii from system menu (or playback settings), when I play audio in volumio, i have the message "Failed to open ALSA device “hw:1,0”: No such file or directory. "
i tried older version of volumio aoide dac, the same thing happened.
i tried to switch off I2C, save, reboot, then re-select Aoide dac ii, without positive solution.
I hear Aoide dac ii with RPI-DAC module, it works, but i can’t select the volume setting, so i can’t hear music with headphones , only with amplifier.
Thnaks in advanc for your help.
Bye.
wilstar
