Hi folks, trying to get wifi to work on a Raspberry Pi running Volumio. First I just tried the web interface to enable wifi. No luck. I then installed and tried wicd-curses, but no matter what I do, it hangs on getting ip address, and then nothing. ifconfig shows the interface is up. I’m using WEP, and have tried all of the authentication options. Trying to just use a hex key to keep it simple. These Edimax dongles supposedly have kernel support. Comes right up on a Windows machine, so I know the hardware is good.
I am running an Edimax 7801, no issues. I found out that in some occasions - trying to put to much config changes into one, nervous impatient finger … - the wifi settings do not get stored correctly. I ssh’d into the pi and checked /etc/network/interfaces and found that the config is basically empty. Manual editing works, but also after rebooting, waiting for a couple minutes until everyhing settles and then making the wifi setting the only change it should work as well.
[i][size=85]Hi - I own a RaspPi B+ and want to use Volumio 1.51 with a Edimax EW-7811Un USB Wireless Adapter. I have a hidden essid and WPA security.
I’m not able to get the adapter to work. Message I get is:
ioctl[SIOCSIWAP]: Operation not permitted
ioctl[SIOCSIWENCODEEXT]: Invalid argument
RTNETLINK answers: File exists
Failed to bring up wlan0.
Any ideas?[/size][/i]
Update
ok - I’ve discovered that when I allow the WiFi-Router to broadcast the ssid WiFi works flawlessly. Strange, but there you go.
I have two Edimax EW-7811Un adapters and editing this file
to include the following code has worked for both.
#use the following for static wireless:
auto wlan0
iface wlan0 inet static
address 192.168.x.x
netmask 255.255.255.0
broadcast 192.168.1.255
gateway 192.168.x.x
wpa-ssid "your ssid"
wpa-psk "your passkey"Note that this uses a static ip address and wpa for encryption, you may have to adapt it to suite your setup. Obviously replace the x’s with your data.
