Anyone able to use the multiroom feature? I can't seem to get it to work
Curious whether anyone is using that feature right now? I have added the subscription for this, but I can’t get it to work.
There are several things happening:
  • Additional player cannot be found.
  • Additional player is found, but can’t be added
  • Additional player is added, but simply doesn’t play any sound on the secondary player.
    Volumio 3 Issues?
I’m running two raspberry pi’s (4b) on the latest and greatest version 3.785.
Logs can be found here:
http://logs.volumio.org/volumio/15Qj90S.html
Thanks!
have you tried disable and enable Multiroom on the devices?
I have four rooms running multisync without issue.
Try resetting your router.
Thanks… Seems to work for now! Would I be able to recognize this from the logs? I’d like to know how to find out what the issue is to prevent it a much as possible…
I’m pretty sure it always comes down to a network issue.
