I had a working configuration with pi3 and hifiberry AMP2. Adding the touchscreen plugin caused the AMP2 to stop working - no audio, no LEDs. It is looking like the installation of the touchscreen plugin removed or disabled the drivers for the AMP2 that are contained in the original raspian kernel. Any suggestions on resolving this issue?
Attempts to check the presence of the AMP2 on the volumio system do not indicate it is present, ie i get this
Subdevices: 7/7
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 IEC958/HDMI [bcm2835 IEC958/HDMI]
Subdevices: 1/1
card 0: ALSA [bcm2835 ALSA], device 2: bcm2835 IEC958/HDMI1 [bcm2835 IEC958/HDMI1]
Subdevices: 1/1
Since the setup was working perfectly fine prior to the installation of the touchscreen drivers, something in the plug-in install damaged the driver installation for the DAC driver for the AMP2…,.
