I have just installed Volumio 2 with the plugin for the raspberry touch display. Well, what a awesome result. Very user friendly and with a speedy interface. Amazing when you compare this with the early versions and the first generation Raspberry. What a huge progress in two years.
Some minor tips:
The keyboard layout was not correct for me. This was the fix:
sudo dpkg-reconfigure keyboard-configuration
At a point Chrome ask me to translate the web page. There are several ways to prevent this message.
- Chrome Settings menu.
- Maybe it is possible that the Volumio html pages have this meta tag:
- Start Chrome with the parameter --disable translate.
