I’m getting occassional split second dropouts when playing through Spotify connect. I get this in the log:
ALSA lib pcm.c:8424:(snd_pcm_recover) underrun occurred
It works fine when streaming from my NAS, so far only getting it with Spotify. Running a Rpi v1.4, with a hardwired connection. Using a I2C DAC.
Is there a ALSA setting I can change to increase the buffer for Spotify Connect?
Do you run cava or some other type of plug in?
What device is this?
No cava.
Running touch display plugin, now playing plugin and gpio buttons.
Rpi4 Rev 1.4, 4gb ram with volumio 3.196
Sorry, by device I meant the ALSA output device
It’s this:
card 1: sndrpirpidac [snd_rpi_rpi_dac], device 0: RPi-DAC HiFi pcm1794a-codec-0 [RPi-DAC HiFi pcm1794a-codec-0]
Subdevices: 1/1
Subdevice #0: subdevice #0
An I2C DAC (Orchard Audio Pecan Pi DAC).
Full log here:
http://logs.volumio.org/volumio/GEqsCFU.html
