Hi, There does not appear to be a plugin for the Allo Relay Attenuator on Volumio V3. Can you please tell me how I can enable this HW or when the plugin will be ready (or if it is not being ported…)
I’m running into the same issue. There’s some documentation on allo’s site. I’ll let you know if I have the time to figure it out!
same here.
Is this still supported?
Hi Pat_L,
I fear we are depending on Allo if they are willing to support the relay attenuator.
I already sent them a request today and i am waiting for an answer.
Maybe you could also send a request to them.
BR
Josef
I certainly will. Thanks
