whats the comparison in sound quality between these three devices?
Im using the IQ audio dac+
Is there a sound difference between the Piano and Piano 2.1?
I might upgrade.
thanks
Funk
I might upgrade.
thanks
Funk
Can’t compare with IQ Audio as I don’t have one.
I do not hear any difference between Piano and Piano 2.1 (in 2.0 mode).
– Gé –
I doubt if you will hear enough difference to make it worth the cost of the upgrade. However, if you add the Kali reclocker to one of the Piano DACs you will, I’m sure, hear a noticeable improvement over the IQ dac.
