The most recent update did not work for me, so I am doing a fresh install on my RPi 3 Model B.
After burning the image of v3.779 to a fresh SD card, my RPi 3 Model B boots up fine, connects to the network, and is assigned an address, but I cannot connect to it via the webUI.
Specifically, although I normally run Volumio headless, I have booted with a monitor attached to see what’s happening, and the bootup seems fine, taking me to a login prompt with the message ‘WebUI available at volumio.local (192.168.0.145)’
Unfortunately, I’m not able to connect to the WebUI via either volumio.local or via 192.168.0.145 (tried both http and https for both). Therefore I’m stuck with an RPi brick.
Any advice on how to make the WebUI connection, or any other way to move through the install, would be appreciated.
Some more info:
-I’m using an eero router, and the RPi is hardwired to the network
-The router shows that ‘volumio’ device is connected, and has the address 192.168.0.145 (consistent with the login screen)
-ping’ing the address gets a response
-ssh’ing to the address tells me that the connection is refused (also seems to indicate the host is up)
-I’m trying to connect via mac and iPhone (both connecting on WiFi)
-the volumio iPhone app that ‘looks for’ volumio devices on the network also cannot find the device either (just endless looping on the screen)
-previously I have disabled WiFi and bluetooth on this RPi, and I’m guessing that those settings will have stuck
Finally, I’ll say that I have been using Volumio (quite happily) for a LONG time (and mpd direct on RPi before that) so this is not my first rodeo. I’ve definitely done my share of Volumio installs and troubleshooting, but this one has me stumped (and quite annoyed).
Many thanks for any help or advice with this.
