Hello!
I am using Allo Piano 2.1 in 2.2 mode with 2 subs (ported custom Visaton 10"). XO is set to 50hz LPF My speakers are Shahinian Obelisks, amps are SoundArt Rock and Nad C 270 (for subs) It sounds more or less the same as my Mac based system (I would say bass is better with Allo, while highs are a bit better with Asus Xonar U7)
2 questions:
- what is the LPF slope for Allo Piano 2.1 in Volumio?
- what is HPF slope for above?
Thanks.
Michal
I’m not totally sure, but I think they are both 24dB/octave Butterworth filters.
Thanks Jonners. What makes you think so?
Sent from my iPhone using Tapatalk
I had an exchange of emails a while ago with one of Allo’s engineers. I checked just now, and he said that they are ‘Butterworth 2’ filters. So they are presumably 2nd order filters with a roll-off of 12dB per octave - not 24dB as I previously stated.
Cool! Thanks. Usually the LPF for subs are 24dB and HPF higher up Frequency are 12dB.
