Hi @ashthespy, Thanks a lot for replying.
I agree with you, on paper it should work with using Master as the playback volume.
Maybe I wasn’t very clear in my solution. I’m using “Master” as the playback option. It does work but only when using the Volumio’s volume control. If I use Spotify’s volume control (in the Spotify App), it only changes the first Dac (L/R) . So maybe SpotifyConnect plugin links to Digital volume and not Master? Sounds like you were saying it’s not in that thread below.
Just read this thread properly and sounds like it’s linked although the sub volume doesn’t fade away after a while.
I agree this is weird and it sounds like you believe the plugin is using the correct Volume Mixer automatically.
As you don’t have a piano 2.1, is there a way for me to see what the SpotifyConnect plugin is using?
{"status":"play","title":"Drone Logic","artist":"Daniel Avery","album":"Drone Logic","albumart":"https://i.scdn.co/image/ab67616d0000b273605da02be8e182bc9966bcc2","uri":"spotify:track:7JRN5xOUIrnI4crUMOt6X4","trackType":"spotify","seek":8001,"duration":430,"samplerate":"44.1 KHz","bitdepth":"16 bit","channels":2,"consume":false,"volume":20,"dbVolume":null,"mute":false,"disableVolumeControl":false,"stream":false,"updatedb":false,"volatile":true,"service":"volspotconnect2"}
Not sure if there is anything useful in there, says that it’s using Master
[SpotifyConnect] Creating VLS config file
info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
xcb_connection_has_error() returned true
info: CoreCommandRouter::volumioUpdateVolumeSettings
info: Updating Volume Controller Parameters: Device: 2 Name: Allo Piano 2.1 Mixer: Master Max Vol: 60 Vol Curve; logarithmic Vol Steps: 2
info: CoreStateMachine::resetVolumioState
info: CoreStateMachine::getcurrentVolume
info: CoreCommandRouter::volumioRetrievevolume
info: CoreCommandRouter::executeOnPlugin: i2s_dacs , getI2sOptions
info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
info: CoreCommandRouter::executeOnPlugin: i2s_dacs , getI2sStatus
info: Getting Alsa Cards List without I2S DAC
info: CoreCommandRouter::executeOnPlugin: i2s_dacs , getI2SNumber
info: CoreCommandRouter::executeOnPlugin: mpd , getConfigParam
info: CoreCommandRouter::executeOnPlugin: mpd , getPlaybackMode
info: CoreCommandRouter::executeOnPlugin: system , getAdvancedSettingsStatus
info: VolumeController:: Volume=20 Mute =false
info: CoreStateMachine::updateTrackBlock
info: CorePlayQueue::getTrackBlock
[SpotifyConnect] Restarting Vollibrespot Daemon
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl restart volspotconnect2.service
Stopping Volspotconnect2 Daemon...
volspotconnect2.service: Main process exited, code=killed, status=15/TERM
volspotconnect2.service: Succeeded.
Stopped Volspotconnect2 Daemon.
Started Volspotconnect2 Daemon.
------------------------------------ BT MESSAGE: BT STATUS: running
BT PLUGIN MESSAGE: Playing: false
BT PLUGIN MESSAGE: VOLATILE: undefined
BT PLUGIN MESSAGE: STATE:undefined
------------------------------------ BT MESSAGE: BT STATUS: waiting
info: MRS: Updating multiroomSync output
[SpotifyConnect] Vollibrespot Daemon service restarted!
vollibrespot v0.2.3 769ce77 2021-06-04 (librespot 08d8bcc 2020-10-07) -- Built On 2021-06-04
Reading Config from "volspotify.toml"
[Vollibrespot] : Using Alsa backend with device: volumio
[Vollibrespot] : Failed to register IPv6 receiver: Os { code: 19, kind: Other, message: "No such device" }
info: VolumeController::SetAlsaVolume20
Let me know if I can help find the issue.
