Allo dual psu
Hello everybody,
Some months a go I bought a Allo dual PSU for my rpi-boss-volt combi, offcourse running Volumio.
After a couple weeks, when I plugged in the PSU I noticed a spark when I put in the wall-plug. From that moment on there was nothing on the PSU anymore. When I plug it in there are no red leds burning. To me it seems like something caused a fuse to blow. Unfortunately the fuse seems to be irreplaceble to me. It is really a pitty, as it was a very quiet PSU.
I contacted Allo about this using de contact form on Allo.com, but unfortunately never got a response. So I guess I can’t expect anything from them.
I have a old laptop PSU, but this one is very noisy. Anybody a suggestion for an alternative PSU for the Volt?
I just informed Allo about your issue, you will receive assitance soon (don’t worry, Allo is spot on with customer support :wink: )
Hi Svenja
can you PM me with your order number etc ?
Michelangelo and Allo,
thank you both for replying. I tried to send a PM, but as I’m a new user I need to participate more to send PMs on this forum :wink: .
I have the order-id and invoice-id right in front of me, but I don’t think it is wise to post it in public. @Allo could you please PM me your mailaddress?
Thanks in advance!
Just click on the allo and then on “send private message”
I don’t have that option, see the screenshot:
I’m interested to buy Dual LLC PSU and I wonder if it works in my system configured as follow:
Raspberry
Kali
Piano2.1
HDD connected via USB to Raspberry
Now I use a iFi iPower for Kali (and Piano 2.1) and a battery pack for Raspberry and HDD, my question is:
Can this Dual LLC PSU substitute both iFi iPower and battery pack?
Anybody can help me on this issue?
