All gone except for BBC Radio 1, interestingly. Many custom URLs that are not easy to obtain, gone. If you are a radio fan, you know what I mean. Don’t allow the update if you listen to radio on Volumio. FYI. I upgraded because I wasn’t told it was a beta. It obviously is. Major feature, crippled. The radio feature is why I liked Volumio. For now? I’ll try re-adding, but might go back to VLC if memories can’t be retained reliably.
I re-entered many of my custom URLs for radio stations and all were lost again after rebooting. Is there a way to save userdata?
You may have a look at the plugin “Backup & Restore Data” which you find under “Search Plugins” -> “System Tools”.
