I just installed Volumio 2023-03-06 on my RP1 using Raspberry PI Imager v1.7.4. Everything went great, except that no images were displayed, even on the Setup Wizard page.
I did it twice, first time from Raspberry Pi Imager → Media player OS → Volumio. The second time, I downloaded the image directly from Get Started | Volumio, and flashed it using Raspberry Pi Imager. Both methods produced the same result.
Same problem on my rpi 4. The manifest ui is much slower than the other options. I ve a really big collection of music. Around the 4tb. I would like to select an other ui, but there is a bug. If I select eigentijds of klassiek, it is not working. I hope there is a solution, because it is very annoying.
I shall check his lpsu. But my rpi has the same problem. En that device is sure at the right voltage.
It has appeared next december 2022. Is seems to be a softwarething. I want to choose another interface, but wenn I press any option, it refreshes always in manifest.
Hi huylv, I have the same problem.
When I try to analyze the problematic image URLs, I find that some image links have an incorrect “undefined” prefix added to them, and in some places, there are two or more additional prefixes. When I manually remove these characters, the images display correctly. So, does anyone know how to resolve this issue?
