I have my album collection of 107 wav files stored on Samsung 2 TB SSD. Currently I am running Volumio 2.917 on a Raspberry Pi 4B, but I had exactly the same issuewith the most recent beta 3 version.
Myfiles are perfectly well recognised when I set the path in the ,Music Library‘ tab and they are updated perfectly normal. But when I want to look at the albums in the ,Albums‘ tab, I see only two! For the life of me I can’t figure out why. Any help is appreciated! Thanks!
@Sailor have you tried the rescan button? Takes a few minutes. Then maybe refresh your browser.
Another thing to check is that the media files have the album data set correctly. You can plug your ssd into a windows computer, select the media files in one of your album directories, right click, go to properties, then details. There you can check or change the ‘Album’ field data.
