for some reason Volumio, from being idle, repeatedly starts playing a playlist without any user interaction at seemingly random times every couple of hours. Has anyone else experienced this?
System: RPi3 Volumio version 2.175, also experienced this behavior with previous versions.
I have an alarm set for 6:00 for that very playlist which also doesn’t go off as expected.
Sorry if this has been reported already, I did look in the forum but couldn’t find anything similar.
not sure, if this helps:
volumio@volumio2:/home$ date
Thu May 18 21:10:33 UTC 2017
(when I have 23:10 CEST, so time set correctly)
Could volspotconnect2 be the trigger for this? (see log below, playlist starts playing @20:08:55)?
$ sudo journalctl > /home/volumio/log.log
May 18 19:52:41 volumio2 wpa_supplicant[811]: wlan0: Cancelling authentication timeout
May 18 19:52:41 volumio2 wpa_supplicant[811]: wlan0: State: GROUP_HANDSHAKE -> COMPLETED
May 18 20:06:35 volumio2 systemd[1]: Starting Volspotconnect2 remove cache service…
May 18 20:06:35 volumio2 systemd[1]: Started Volspotconnect2 remove cache service.
May 18 20:06:35 volumio2 volumio[4972]: cache not full, nothing do
May 18 20:08:55 volumio2 volumio[887]: info: [1495138135027] Play playlist Radio Paradise
May 18 20:08:55 volumio2 volumio[887]: info: [1495138135034] Play playlist Radio Paradise
May 18 20:08:55 volumio2 volumio[887]: info: CoreCommandRouter::volumioClearQueue
May 18 20:08:55 volumio2 volumio[887]: info: [1495138135041] CoreStateMachine::ClearQueue
May 18 20:08:55 volumio2 volumio[887]: info: [1495138135041] CoreStateMachine::stop
May 18 20:08:55 volumio2 volumio[887]: info: [1495138135042] CoreStateMachine::setConsumeUpdateService undefined
May 18 20:08:55 volumio2 volumio[887]: UNSET VOLATILE
May 18 20:08:55 volumio2 volumio[887]: info: [1495138135043] CorePlayQueue::clearPlayQueue
May 18 20:08:55 volumio2 volumio[887]: info: [1495138135044] CorePlayQueue::saveQueue
May 18 20:08:55 volumio2 volumio[887]: info: [1495138135045] CoreStateMachine::pushEmptyState
May 18 20:08:55 volumio2 volumio[887]: info: CoreCommandRouter::volumioPushState
May 18 20:08:55 volumio2 volumio[887]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
May 18 20:08:55 volumio2 volumio[887]: info: [1495138135047] interfaceApi::pushState
May 18 20:08:55 volumio2 volumio[887]: info: [1495138135048] InterfaceWebUI::pushState
May 18 20:08:55 volumio2 volumio[887]: info: CoreCommandRouter::volumioPushQueue
May 18 20:08:55 volumio2 volumio[887]: info: [1495138135063] interfaceApi::pushQueue
May 18 20:08:55 volumio2 volumio[887]: info: [1495138135064] InterfaceWebUI::pushQueue
May 18 20:08:55 volumio2 volumio[887]: info: CoreCommandRouter::volumioAddQueueItems
May 18 20:08:55 volumio2 volumio[887]: info: [1495138135070] CoreStateMachine::addQueueItems
May 18 20:08:55 volumio2 volumio[887]: info: [1495138135070] CorePlayQueue::addQueueItems
May 18 20:08:55 volumio2 volumio[887]: info: uri=http://stream-dc1.radioparadise.com/rp_192m.ogg, service=webradio
May 18 20:08:55 volumio2 volumio[887]: info: First index is 0
May 18 20:08:55 volumio2 volumio[887]: info: ADDING THIS ITEM TO QUEUE: {“uri”:“http://stream-dc1.radioparadise.com/rp_192m.ogg",“service”:"webradio”}
May 18 20:08:55 volumio2 volumio[887]: info: [1495138135076] CorePlayQueue::saveQueue
May 18 20:08:55 volumio2 volumio[887]: info: Adding item to queue: {“uri”:“http://stream-dc1.radioparadise.com/rp_192m.ogg",“service”:“webradio”,“albumart”:"/albumart",“samplerate”:"",“bitdepth”:0,"channels”:0}
