Airplay
Hi!
I have a rpi2 with hifiberry amp running Volumio 2. I don’t get any sound when trying airplay. Volumio shows up on the Ipad, but I get no sound when choosing it… something I missed?
Disable software volume, set volume control to none. This is an issue we’re solving
I´ve the same problem! When will the release this issue is solved be available?
Regards Christian
I cannot fix it with this instructions. Where do I disable software volume? And set volume controle to none, means volume om zero? I tried but no effect.
