System
- Volumio: 4.119
- FusionDSP: 3.0.6
- Hardware: Raspberry Pi 4 (4 GB)
- DAC: HiFiBerry AMP4 Pro
- Audio source: Apple Music via AirPlay
- AirPlay: shairport-sync (default Volumio configuration)
Problem
AirPlay playback works perfectly until FusionDSP is enabled.
As soon as FusionDSP is enabled, AirPlay playback starts to stutter heavily with irregular audio dropouts.
The dropouts are not periodic. They occur randomly every few seconds.
What works perfectly
- Webradio
- Local playback
- FusionDSP with multiple filters enabled
- Loudness
- High Shelf
- Low Shelf
- Peaking EQ
- Gain
No stuttering occurs with these sources.
What does NOT work
- Apple Music via AirPlay
- FusionDSP enabled
Even with an empty DSP configuration, AirPlay stutters immediately.
Important finding
I completely removed all DSP processing.
Current CamillaDSP configuration:
filters: {}
mixers: {}
pipeline: []
Therefore no DSP processing is taking place.
The audio is only routed through FusionDSP/CamillaDSP.
Nevertheless AirPlay still stutters.
This suggests that the issue is not related to DSP filters.
Diagnostics performed
CPU
CPU usage remains low.
No overload.
Memory
More than enough free RAM.
CamillaDSP
Running normally.
No crashes.
No restarts.
DSP load approximately 0.5%.
ALSA
Routing appears correct:
Shairport
volumio
FusionDSP FIFO
CamillaDSP
HiFiBerry AMP4 Pro
Sample rate
AirPlay stream parameters:
44100,S32_LE,2,32
No unexpected sample-rate conversion.
CamillaDSP log
No underruns or FIFO errors.
Only clipping warnings when intentionally boosting EQ:
Clipping detected
These disappear after reducing gain and are unrelated to the stuttering.
Additional observations
Changing
queuelimit: 1
to
queuelimit: 8
did not improve the problem.
Reproduction
- Disable FusionDSP
- Play Apple Music via AirPlay
- Playback is perfect
Then
- Enable FusionDSP
- Leave DSP completely empty
- Play the same AirPlay stream
Result:
Immediate heavy random stuttering.
Comparison
| Source | FusionDSP | Result |
| Webradio | OFF | OK |
| Webradio | ON | OK |
| Webradio + Filters | ON | OK |
| AirPlay | OFF | OK |
| AirPlay | ON | Heavy random stuttering |
Question
Is this a known issue between Shairport-sync and FusionDSP 3.0.6?
Since the problem also occurs with an empty DSP pipeline, it appears that the issue is somewhere in the AirPlay → FusionDSP audio path rather than in CamillaDSP processing itself.
Any suggestions for additional debugging would be greatly appreciated.
