After upgrading to version 2.729, I cannot longer Airplay from iOS13. I have disabled and re-enabled sharepoint-sync a couple of times, no go. I have tried doing a Run first config Wizard, no go. Is this a known issue? Any workarounds? Does the previous version work with Airplay?
Please try to do a factory reset, it should work after that.
Sorry for the hassle: there is something unclear on why it happens that we’re still tring to figure out
Thanks. I ended reinstalling the entire image but went with 2.699. No big deal. It works now. I will test the upgrade and reset it in a bit. Thanks for the great work, it is an amazing airplay solution for my older receivers…
Did you have plugins installed in your previous build when airplay stopped working?
