Hi Forum,
I am having problem with Airplay. My Android with Apple Music installed doesn’t see the Volumio when trying to cast to it. [no icon to cast] According to Apple it should be visible when there is receiver nearby
I am able to cast from Spotify with no issues.
Following demon is running on Volumio:
shairport-sync.service loaded active running Shairport Sync - AirPlay Audio Receiver
failed/not running services:
spop.service loaded failed failed Spotify Daemon
<97><8F> dhcpcd.service loaded failed failed LSB: IPv4 DHCP client with IPv4LL support
I didn’t mees with configuration etc [vanila build] I have no iOS device to test
Please advise
