When using Volumio to relay the bits to the USB port over Airplay the DAC is indicating a frequency of 44.1kHz. Is that limited to the Airplay protocol ? If so, is there a way to circumvent that limitation ?. Thank’s
Greetings
Greetings
Yes it is. There is no/I don´t know a way to circumvent this.
Why did you use an open source audiophile player to send music to some overpriced, bad sounding, limited Apple Bulls**t ?
There’s plenty of non limited DLNA receptors out there … ex :
and a cheaper one form SMSL in my memory …
