This is my 3rd question to the forum. My first 2 went unanswered. They were either too stupid to deserve an answer or people don’t know the answer.
Here we go with my 3rd:
When Airplay is active, is there a place where volumio tracks information about it? Basically I’m developing a script to start a slideshow screensaver when the player is in pause or stop mode and close it when play state is on. I got it working using the state_file and using the player buttons. However when airplaying, the player is not aware that the state is in play mode and it still thinks it’s in pause/stop mode. Basically the state_file only works with local music and activating local player buttons or via web or app.
What file can I tap into to find the state of the player when airplaying? I looked at running processes but nothing there. There must be a place or a file where it writes some data about what’s streaming via airplay.
Now sure what you mean by the state_file – that is specific to mpd, while airplay is using a different service.
What you probably should be looking into is the provided Volumio APIs https://volumio.github.io/docs/API/API_Overview.html particularly the websocket one if you are interested in state tracking.
Thanks for the info. The state file is created by mpd when music starts or stops. Inside the state file the state if the player is recorded and can be tapped into to check the state. Now I know that airplay doesn’t use mpd so I need to look elsewhere.
I was hoping that during airplay a file is created somewhere in the system. If that was the case I could easily implement an “if file exists exit screensaver” and the opposite, "if file doesn’t exist and state is stop/pause start the screensaver.
If you are planning to run this on the device itself, try typing volumio status.
But the methods your describing are all polling methods, whereas with the websocket API you could subscribe to the state. Try reading my previous links to the API…
That’s exactly what I was looking for. Thanks. I’m not much of a scripter and I know enough to get into trouble so I don’t need to make it too elegant. Your info helped me to get it working. However, I can’t get the script to start at reboot using the @reboot in crontab. I tried to put the sh script in a few locations but nothing is starting. The script works well when launched manually. Any advice? Thanks.
My script under /usr/bin. Don’t laugh, I’m not a programmer:
#!/bin/bash
#Path to photos
PHOTO_FOLDER=/mnt/LocalHDD/Pictures
while true
do
(volumio status) > /home/volumio/screensaver/status
STAT=/home/volumio/screensaver/status
grep -q ': "play",' $STAT
if [ $? != 0 ]; then
if ! pgrep -x "feh" > /dev/null; then
DISPLAY=:0 feh -ZXYrzFD 10 $PHOTO_FOLDER &
fi
else
pidof feh && pkill feh
fi
sleep 10s
done
I run:
systemctl enable screensaver.service
systemctl start screensaver.system
systemctl -l status screensaver.service # and I get this:
● screensaver.service - Screensaver
Loaded: loaded (/lib/systemd/system/screensaver.service; enabled)
Active: activating (start) since Wed 2021-08-25 23:51:17 UTC; 4min 14s ago
Main PID: 623 (screensaver.sh)
CGroup: /system.slice/screensaver.service
├─ 623 /bin/bash /usr/bin/screensaver.sh
└─2379 sleep 10s
Aug 25 23:54:51 volumio screensaver.sh[623]: No protocol specified
Aug 25 23:54:51 volumio screensaver.sh[623]: feh ERROR: Can't open X display. It *is* running, yeah?
Aug 25 23:55:01 volumio screensaver.sh[623]: No protocol specified
Aug 25 23:55:01 volumio screensaver.sh[623]: feh ERROR: Can't open X display. It *is* running, yeah?
Aug 25 23:55:11 volumio screensaver.sh[623]: No protocol specified
Aug 25 23:55:11 volumio screensaver.sh[623]: feh ERROR: Can't open X display. It *is* running, yeah?
Aug 25 23:55:21 volumio screensaver.sh[623]: No protocol specified
Aug 25 23:55:21 volumio screensaver.sh[623]: feh ERROR: Can't open X display. It *is* running, yeah?
Aug 25 23:55:31 volumio screensaver.sh[623]: No protocol specified
Aug 25 23:55:31 volumio screensaver.sh[623]: feh ERROR: Can't open X display. It *is* running, yeah?
– Do you have a X display up and running? Simplest way would probably be using the Touch Display plugin
I would get your screen saver up and running first, and once ironed out move on the the state parsing for Volumio.
– With (volumio status) > /home/volumio/screensaver/status you are creating a file every 10s, not sure if your SD card would like that. Instead, if you need the file write to /tmp or you can just store the output in a variable.
Instead something like this might be easer
#!/bin/bash
#Path to photos
while true; do
if volumio status | grep -q ': "play",'; then
# Playing
else
# Stopped
if ! pgrep -x "feh" >/dev/null; then
fi
fi
sleep 10s
done
Optionally, you can use jq to parse the json response directly
status=$(volumio status | jq -r .status)
case "${status}" in
play)
stop)
fi
# Something is wrong
esac
wow, that’s amazing. I couldn’t get the result directly from volumio status so I wrote to disk. Thanks a lot, now it runs more efficient.
I’m running 2.907 on a laptop without touch display. The final product will have a touch display but it will not be used as such, although the touch is working out of the box without any plugins or any settings changes.
How can I get the new script to start when booted and run in the background. Do I still create a service for like I mentioned in the previous post?
I made it into a service with the steps above and it looks like it starts at reboot and when I look at the service status I get this referring to x window again. No clue what that is.
volumio@volumio:~$ systemctl status screensaver.service
Active: activating (start) since Thu 2021-08-26 20:00:11 UTC; 6min ago
Main PID: 620 (screensaver2.sh)
├─ 620 /bin/bash /usr/bin/screensaver2.sh
└─2715 sleep 10s
Aug 26 20:05:35 volumio screensaver2.sh[620]: No protocol specified
Aug 26 20:05:35 volumio screensaver2.sh[620]: feh ERROR: Can't open X display. It *is* running, yeah?
Aug 26 20:05:45 volumio screensaver2.sh[620]: No protocol specified
Aug 26 20:05:45 volumio screensaver2.sh[620]: feh ERROR: Can't open X display. It *is* running, yeah?
Aug 26 20:05:55 volumio screensaver2.sh[620]: No protocol specified
Aug 26 20:05:55 volumio screensaver2.sh[620]: feh ERROR: Can't open X display. It *is* running, yeah?
Aug 26 20:06:05 volumio screensaver2.sh[620]: No protocol specified
Aug 26 20:06:05 volumio screensaver2.sh[620]: feh ERROR: Can't open X display. It *is* running, yeah?
Aug 26 20:06:15 volumio screensaver2.sh[620]: No protocol specified
Aug 26 20:06:15 volumio screensaver2.sh[620]: feh ERROR: Can't open X display. It *is* running, yeah?
Also, if I run the sh script from the command line it works fine. If I run the same script with sudo I get the same error:
Aug 26 20:06:15 volumio screensaver2.sh[620]: feh ERROR: Can’t open X display. It *is* running, yeah?
Anything to do with rights? I’ve added a few lines to the script based on this error and none made a difference. Don’t know what any of them do but they were suggestions by others for the same error:
I got it working. Tried a lot of command until the right combo worked. When I start the service from command everything works well with no errors. However, although the service is enabled, it doesn’t start at startup, but it starts manually and works fine. Here is the status after a reboot:
#!/bin/bash
sleep 60
export HOME=/home/volumio
export DISPLAY=:0
#Path to photos
while true; do
# Playing
else
# Stopped
fi
fi
sleep 11s
done
#!/bin/bash
# These should not longer be required
#sleep 60
#export HOME=/home/volumio
#export DISPLAY=:0
#Path to photos
while true; do
# Playing
else
# Stopped
fi
fi
sleep 11s
done
When I put user/group as volumio the service doesn’t start manually or at reboot.
when I take out “export HOME=/home/volumio” I get the error:
Aug 27 15:23:52 volumio screensaver2.sh[1843]: No protocol specified
Aug 27 15:23:52 volumio screensaver2.sh[1843]: feh ERROR: Can’t open X display. It is running, yeah?
My only problem now is that the service doesn’t start at reboot but it starts and works ok when done manually. After a reboot, the status shows as:
volumio@volumio:~$ systemctl -l status screensaver
Active: inactive (dead)
Am I missing something to make it start automatically at reboot?
Hmm, I unfortunately run all my devices headless, so can’t test things out for you…
Some ideas though
– Check if the service hasn’t launched and exited on a fresh startup?
– Add a few echo statements to your script to debug
