Airplay Icon gone
So Volumio used to run just fine, now I’m on 1.3 and using a Hifiberry. There is no Airplay icon anymore in my iTunes nor in System Preferences (I’m on a Macbook)
Any ideas?
Yes, is a bug I already fixed. Monday you’ll find a new release with this fixed.
if you can’t wait just connect via ssh and do
chmod a+x /etc/init.d/shairport update-rc.d shairport defaults
And reboot. Let me know
thanks, I’ve tried that and got the following message on my system:
root@volumio:/# chmod a+x /etc/init.d/shairport root@volumio:/# update-rc.d shairport defaults update-rc.d: using dependency based boot sequencing insserv: warning: script 'K02shairport' missing LSB tags and overrides insserv: warning: script 'shairport' missing LSB tags and overrides
The automatic launch of shairport at startup does not work.
I can start the shairport manually using /etc/init.d/shairport start, but it does not launch at boot.
Using CuBox i4 Pro, Volumio beta 1.2
