I updated to VERSION: 2.389. Previously I was able to listen to 24/96 files in dual mono using the piano 2.1 Dac. After the update the 24/96 only produces static.
I then performed a clean install to VERSION: 2.389 but it didn’t fix the problem.
I can listen to 24/96 files using the Allo Boss driver but not the Piano 2.1 setting.
Any suggestions would be greatly apprecated.
Dana
