Hi
After update no control over mobile phone possible
I´ve update and upgrade the software on se SD-card with sudo apt-get update and sudo apt-get upgrade now the controll with mobil are inte working. Did you have an idea what has can have happend ? Thanks
WBR
Jörg
Don’t do this or you are likely to break your system.
