hi all
can i connect the volumio preciso to my denon2700h and will i have any improvment on the sound
thank you
Hi
Are we talking Denon avr x2700H ?
If so yes you can connect preciso to denon with rca analog cables
But if it will gain for better is all up to the onboard dac Inside denon and how its perform.
One way to find out os to try it and let you ears do the rest
