Address other than 192.168
Been trying to configure volumio on my network but the wireless connection does not work at all. If connected with a lan cable it works but i do not have network connection close to my audio setup. If I do an ifconfig it will return ip address for the eth0 but never for the wireless even when it validates the password when entered.
I’m using a Raspi 3 B with the latest image. The router provided by my service provider works on the 10.0.0.x range not the default 192.168 so I’m starting to think this is an issue by what I have read around.
For future reference, issue is related to github.com/volumio/Volumio2/issues/1379 . Had to reimage sd card and manually enter the wlan instead of selecting from the ones in screen on initial wizard setup.
