Running Volumio 3 on a Raspberry Pi 5 with all my music on the local SD.
I installed an inno-maker DAC pcm512x and it works fine except all music plays at half-speed which is really creepy. Tried to switch back to the HDMI out and that gets Error 524 (which I think means no output).
Am logged into Volumio on the Pi.
Solutions/thoughts?
dvo
June 22, 2024, 2:51pm
2
rthepenguin:
@Wheaten do you know if we are patched for this?
opened 09:08AM - 11 Jan 24 UTC
closed 12:24PM - 30 Jan 24 UTC
### Describe the bug
I am trying to get the Allo Boss HAT to work on the PI5 an… d kernel 6.6.9.
I am not sure if I got the config.txt correct.
As you can see below all related modules are being loaded though.
It still fails. Alsa doesn't see it.
config.txt
###audio#####################
###disable onboard audio
dtparam=audio=off
###I2C
dtoverlay=i2c0-pi5
dtparam=i2c_arm=on
###I2S
dtparam=i2s=on
###audiointerface_overlay
dtoverlay=allo-boss-dac-pcm512x-audio
lsmod | grep snd
snd_soc_allo_boss_dac 49152 0
snd_soc_pcm512x_i2c 49152 0
snd_soc_pcm512x 49152 1 snd_soc_pcm512x_i2c
regmap_i2c 49152 1 snd_soc_pcm512x_i2c
snd_soc_core 327680 3 snd_soc_pcm512x,snd_soc_allo_boss_dac,designware_i2s
snd_compress 49152 1 snd_soc_core
snd_pcm_dmaengine 49152 1 snd_soc_core
snd_pcm 163840 6 snd_soc_pcm512x,snd_soc_allo_boss_dac,designware_i2s,snd_compress,snd_soc_core,snd_pcm_dmaengine
snd_timer 65536 1 snd_pcm
snd 147456 5 snd_soc_pcm512x,snd_timer,snd_compress,snd_soc_core,snd_pcm
dmesg
[ 0.060230] bcm2708_fb soc:fb: Unable to determine number of FBs. Disabling driver.
[ 1.661521] pcm512x 1-004d: Failed to reset device: -121
[ 1.731789] snd-allo-boss-dac soc:sound: snd_soc_register_card() failed: -517
[ 11.744424] snd-allo-boss-dac soc:sound: snd_soc_register_card() failed: -517
### Steps to reproduce the behaviour
NA
### Device (s)
Other
### System
2023/12/14 16:43:25
6.6.9-rpi-2712
latest 64bit RPiOS (pi-gen)
### Logs
See text above
### Additional context
_No response_
dewen
June 25, 2024, 2:29am
3
Hi @rthepenguin
I use Pi 5 and the same DAC without problem,
please post your /boot/config.txt
maybe I can help.
thank you.
