Add some actions on playing screen
HI
On the “on playing screen”, I that possible to add the following things ?
% of volume level close to the + button,
A button to switch on/off the loudness . I know we can go to the sub screen for that, but this is not easy to find in the list of settings they are in.
A button to mute, may be would be better to have it on the main screen.
Regards
Georges
HI
Any comments from the product dev ?
Are they make sense ?
Do you need more explanation ?
Georges
Take a look at the now playing plugin
What should have seen ? is that something new I have not in my current version 3.5.1.2 ?
Almost :wink:
Hum
I think I did not explain correctly.
What I am asking is the possibility to have a button to switch on/off the Loudness directly on the screen where you have the volume slider
Sorry, indeed I didn’t get that.
Currently it’s not possible without modifying seeded coding.
It won’t give you a loudness toggle, but I agree with what @Wheaten recommended, the Now Playing plugin. This gives you huge frredom to play with screen layouts … including % volume.
&volume and loudness toogfle ?
I now that any improvment needs to add/change coding and layout. But this one would improve the user experience.
Thanks georges
Hi Georges,
You can add at as a feature request.
How to proceed ?
Place a topic here:
A post was split to a new topic: [UI] Make select attribute searchable [UI]
