"Add, replace and play" functionality greatly missed on V,2
Hello
This is more a suggestion rather than a request for help.
In the first version of Volumio there used to be an option when browsing your music library to “Add, replace and play”. Under Volumio 2 this option has disappeared, One needs to go under “Queue” (formerly playlist", delete the playlist, go back to “Browse” and then add the desired folder. This process is painful and I would very much welcome seeing in Volumio 2 the same old option than in Volumio 1.
Thank you all for the fantastic works you are doing on the development of Volumio.
Regards,
Marc
In fact we just added it, it’s now called clear and play :wink:
