Here is a quick cut and paste of my notes to install AlsaEqual on Volumio
It has been a while since I have done this, but it should work for you
Start with a vanilla copy of Volumio 1.5x
You will need software for your PC to make it emulate a terminal and have the ability to log into your Pi using secure shell, known as SSH. I recommend Putty which is free, very mature and stable. See putty.org.
For general Equalizer information, see:
See: forums.debian.net/viewtopic.php? … 6f5649a186
And: pclosmag.com/html/Issues/201304/page10.html
And: thedigitalmachine.net/alsaequal.html
And: volumio.org/forum/equalizer-t45-10.html#p9947
update RPi stuff with:
rpi-update
Then:
apt-get update (there will likely be some warnings)
apt-get install libasound2-plugin-equal (answer Y when prompted)
If this fails, save /etc/apt/sources.list and replace with:
deb archive.raspbian.org/raspbian jessie main contrib non-free
deb-src archive.raspbian.org/raspbian jessie main contrib non-free
deb repo.volumio.org/apt/ jessie main contrib
find sound card in use on your system:
aplay -l (for me card and device = 0:0)
Create /etc/asound.conf:
nano /etc/asound.conf
paste in the following lines and save:
ctl.equal {
type equal;
pcm.plugequal {
type equal;
slave.pcm “plughw:0,0”; #card1 would be plughw:1,0
#pcm.equal {
Or if you want the equalizer to be your
default soundcard uncomment the following
line and comment the above line.
pcm.!default{
type plug;
slave.pcm plugequal;
Then edit mpd.conf:
cp -p /etc/mpd.conf /etc/mpd.conf.orig
nano /etc/mpd.conf and paste at the bottom (or edit the audio_output section):
audio_output {
type "alsa"
name "Output"
#name "equal"
device "hw:0,0"
mixer_control "PCM"
#mixer_control "Master" #May allow volume control on some DACs
mixer_device "hw:0" #edit in case your soundcard is not card0
mixer_index "0"
dop "no"
Restart mpd:
sudo service mpd restart (ignore the warning about “share” if you get it)
If needed:
/etc/init.d/alsa-utils restart
Run equalizer in a terminal window (i.e “Putty”)… run as user mpd:
sudo -H -u mpd alsamixer -D equal
You should see a ten octave EQ
Use left-right arrows to select an octave
Use up-down arrows to increase-decrease volume of selected octave
Q-W-E respectively increase volume for the left-combined-right channels in the selected octave
Z-X-C respectively decrease volume for the left-combined-right channels in the selected octave
Alsaequal creates /var/lib/mpd/.alasequal.bin when an EQ profile is saved
See also:
en.wikipedia.org/wiki/Alsamixer#Mixer_views
linux.die.net/man/1/alsamixer
alsa.opensrc.org/Alsamixer
OR try gnome-alsamixer
sudo apt-get install gnome-alsamixer
see: packages.debian.org/wheezy/gnome-alsamixer
