Hi Dev Team,
I use my second volumio pi in my bedroom mostly for an alarm, but sometimes i like to listen to music as i go to sleep. The issue is that the volume is always much lower when i want to sleep than when I want it to wake me up. Is there a way to add a “Set alarm volume” option when you set up the alarm, something like how you set the playlist?
That way you could fall asleep to something on a low volume but then have it loud enough to wake the dead (or just me) in the morning…
FYI I tried doing this via a cron job but couldnt figure out how to set up cron on V3, but if someone knew how to do this that would be great
Thanks!
