I just installed Volumio to try it and it seems that i have a problem with my router.
Actually, my router (an Livebox from Orange) diffuse 2 SSID. One on 2.4Ghz and the other on 5Ghz. But both are in the same network (192.168.1.0/24)
Volumio is installed on a RPI Zero W and connected on the 2.4Ghz SSID
If my computer is on the 2.4Ghz network, no problems, it works fine !
But if it is on the 5Ghz network, it impossible to access volumio …
Do you have an idea ?
I think the problem is from Volumio, i have an other RPI (V2) with Max2play, and i can access it from the two SSID
My wireless router broadcast 2 SSID, one on the 5Ghz, one on the 2.4Ghz, but regardless of the SSID, it already the same network (192.168.1.0/24).
My problem is :
If RPI (with volumio) connected to the 2.4Ghz and my computer connected to 5Ghz, i can’t access the RPI from the computer (access via HTTP or for streaming)
If RPI (with volumio) connected to 2.4Ghz and my computer too, i don’t have any problem, i can browse volumio, stream music to it etc …
But if i use a Max2Play distribution (for example), regarless the SSID which is connected the computer, i can already access the RPI
