Hi all,
Been playing with Volumio on a Pi 4 B, and it’s been great so far!
I’d like to run a panel light with a 6v bayonet-style LED bulb as the “On” light - i.e., it turns on when Volumio starts, and turns off on shutdown. I don’t want to run it on one of the 5v pins, because then it’s always on as long as the Pi has power, regardless of what Volumio is doing.
Is there a good way to do this using a GPIO pin and the plugin? Do I need a converter inbetween the pin and the bulb?
