Hi All,
I’m new to Volumio but loving it so far, so thanks!
I’ve got it running on an RPi4 and have been running BOINC projects on that RPi. Some of the projects - specifically Rosetta@home - only run on a 64-bit enabled OS, but I understand that often breaks compatibility with 32-bit apps and modules. Is it possible to run Volumio on an RPi3 or 4 if the OS is running in 64-bit mode? Rosetta is particularly relevant at the moment because they’re doing Coronavirus protein research, so if I can get it running on the Pi in the background then everyone wins, but I understand it’s unlikely to be that simple!
thanks
Danny
