I downloaded and installed the latest Volumio version yesterday and tried installing the 503 HTA Tube Amp GPIO Plugin and noticed that the plugin is failing to start. It appears there is a Node.js version issue:
Mar 26 17:09:32 ryan-volumio volumio[1007]: info: Enabling plugin 503_hta_tube_amp
Mar 26 17:09:32 ryan-volumio volumio[1007]: info: Loading plugin "503_hta_tube_amp"...
Mar 26 17:09:32 ryan-volumio volumio[1007]: error: !!!! WARNING !!!!
Mar 26 17:09:32 ryan-volumio volumio[1007]: error: The plugin miscellanea/503_hta_tube_amp failed to load, setting it to stopped. Error: Error: The module '/data/plugins/miscellanea/503_hta_tube_amp/node_modules/epoll/build/Release/epoll.node'
Mar 26 17:09:32 ryan-volumio volumio[1007]: was compiled against a different Node.js version using
Mar 26 17:09:32 ryan-volumio volumio[1007]: NODE_MODULE_VERSION 48. This version of Node.js requires
Mar 26 17:09:32 ryan-volumio volumio[1007]: NODE_MODULE_VERSION 57. Please try re-compiling or re-installing
Mar 26 17:09:32 ryan-volumio volumio[1007]: the module (for instance, using `npm rebuild` or `npm install`).
Mar 26 17:09:32 ryan-volumio volumio[1007]: error: Stack trace: Error: The module '/data/plugins/miscellanea/503_hta_tube_amp/node_modules/epoll/build/Release/epoll.node'
Mar 26 17:09:32 ryan-volumio volumio[1007]: at Object.Module._extensions..node (module.js:681:18)
Mar 26 17:09:32 ryan-volumio volumio[1007]: at Module.load (module.js:565:32)
Mar 26 17:09:32 ryan-volumio volumio[1007]: at tryModuleLoad (module.js:505:12)
Mar 26 17:09:32 ryan-volumio volumio[1007]: at Function.Module._load (module.js:497:3)
Mar 26 17:09:32 ryan-volumio volumio[1007]: at Module.require (module.js:596:17)
Mar 26 17:09:32 ryan-volumio volumio[1007]: at require (internal/module.js:11:18)
Mar 26 17:09:32 ryan-volumio volumio[1007]: at bindings (/data/plugins/miscellanea/503_hta_tube_amp/node_modules/bindings/bindings.js:76:44)
Mar 26 17:09:32 ryan-volumio volumio[1007]: at Object.<anonymous> (/data/plugins/miscellanea/503_hta_tube_amp/node_modules/epoll/epoll.js:1:99)
Mar 26 17:09:32 ryan-volumio volumio[1007]: at Module._compile (module.js:652:30)
Mar 26 17:09:32 ryan-volumio volumio[1007]: at Object.Module._extensions..js (module.js:663:10)
Mar 26 17:09:32 ryan-volumio volumio[1007]: at Object.<anonymous> (/data/plugins/miscellanea/503_hta_tube_amp/node_modules/onoff/onoff.js:4:11)
Mar 26 17:09:32 ryan-volumio volumio[1007]: info: Done.
