Is it just me ??? [code]pi@volumio:~$ sudo apt-get update
Ign http://repo.volumio.org jessie Release.gpg
Hit http://mirrordirector.raspbian.org jessie Release.gpg
Hit http://mirrordirector.raspbian.org wheezy Release.gpg
Ign http://repo.volumio.org jessie/main armhf Packages/DiffIndex
Hit http://mirrordirector.raspbian.org jessie/main armhf Packages
Ign http://repo.volumio.org jessie/contrib armhf Packages/DiffIndex
Hit http://mirrordirector.raspbian.org wheezy/main Sources
Ign http://mirrordirector.raspbian.org jessie/main Translation-en_GB
Ign http://repo.volumio.org jessie/contrib Translation-en_GB
Ign http://repo.volumio.org jessie/main Translation-en_GB
Err http://repo.volumio.org jessie/main armhf Packages
500 Internal Server Error
Err http://repo.volumio.org jessie/contrib armhf Packages
W: Failed to fetch http://repo.volumio.org/apt/dists/jessie/main/binary-armhf/Packages 500 Internal Server Error
W: Failed to fetch http://repo.volumio.org/apt/dists/jessie/contrib/binary-armhf/Packages 500 Internal Server Error
E: Some index files failed to download. They have been ignored, or old ones used instead.
pi@volumio:~$[/code]
it will soon be updated distribution ??? or this is a bug ???
Looks like it’s you; here’s what I just got:
Get:1 http://archive.raspberrypi.org wheezy Release.gpg [490 B]
Get:2 http://archive.raspbian.org wheezy Release.gpg [490 B]
Get:3 http://mirrordirector.raspbian.org wheezy Release.gpg [490 B]
Get:4 http://archive.raspberrypi.org wheezy Release [10.2 kB]
Get:5 http://archive.raspbian.org wheezy Release [14.4 kB]
Get:6 http://mirrordirector.raspbian.org wheezy Release [14.4 kB]
Get:7 http://archive.raspberrypi.org wheezy/main armhf Packages [106 kB]
Get:8 http://mirrordirector.raspbian.org wheezy/main Sources [6,072 kB]
Get:9 http://archive.raspbian.org wheezy/main Sources [6,072 kB]
Ign http://archive.raspberrypi.org wheezy/main Translation-en_GB
Get:10 http://mirrordirector.raspbian.org wheezy/main armhf Packages [6,893 kB]
Hit http://archive.raspbian.org wheezy/contrib Sources
Hit http://archive.raspbian.org wheezy/non-free Sources
Hit http://archive.raspbian.org wheezy/rpi Sources
Get:11 http://archive.raspbian.org wheezy/main armhf Packages [6,893 kB]
Ign http://mirrordirector.raspbian.org wheezy/main Translation-en_GB
Hit http://archive.raspbian.org wheezy/contrib armhf Packages
Hit http://archive.raspbian.org wheezy/non-free armhf Packages
Hit http://archive.raspbian.org wheezy/rpi armhf Packages
Ign http://archive.raspbian.org wheezy/contrib Translation-en_GB
Ign http://archive.raspbian.org wheezy/main Translation-en_GB
Ign http://archive.raspbian.org wheezy/non-free Translation-en_GB
Ign http://archive.raspbian.org wheezy/rpi Translation-en_GB
Fetched 26.1 MB in 2min 11s (198 kB/s)
Reading package lists... Done
pi@volumio:~$
New install v.1.51 :
/etc/apt/sources.list
deb http://repo.volumio.org/apt/ jessie main contrib
deb http://mirrordirector.raspbian.org/raspbian/ jessie main
deb-src http://mirrordirector.raspbian.org/raspbian/ wheezy main
хостинг изображений gif
What your sources.list ???
Absolutely standard as per Volumio 1.2 (can’t get on with the latest ones yet…)_
pi@volumio:~$ cat /etc/apt/sources.list
deb mirrordirector.raspbian.org/raspbian/ wheezy main
deb-src mirrordirector.raspbian.org/raspbian/ wheezy main
Raspberry Pi Foundation official repository
deb archive.raspberrypi.org/debian wheezy main
deb archive.raspbian.org/raspbian wheezy main contrib non-free rpi
deb-src archive.raspbian.org/raspbian wheezy main contrib non-free rpi
I have the same problem for about 2 weeks:
pi@volumio:/etc$ sudo apt-get update
Get:1 http://mirrordirector.raspbian.org jessie Release.gpg [490 B]
Get:2 http://mirrordirector.raspbian.org wheezy Release.gpg [490 B]
Get:3 http://mirrordirector.raspbian.org jessie Release [14.4 kB]
Get:4 http://mirrordirector.raspbian.org wheezy Release [14.4 kB]
Get:5 http://mirrordirector.raspbian.org jessie/main armhf Packages [8,960 kB]
Get:6 http://mirrordirector.raspbian.org wheezy/main Sources [6,072 kB]
Fetched 15.1 MB in 1min 13s (205 kB/s)
pi@volumio:/etc$ cat /etc/apt/sources.list
Should I upgrade the system or some of the packages?
I delete this line
and now install apps . But maybe this don’t correctly.
tatoosh
January 11, 2015, 10:28am
7
Same problem here. Any solutions already?
Just thinking about this (and thinking is something I don’t often do…), you have a problem using ‘jessie’ and I don’t have a problem using ‘wheezy’; if you’re using ‘jessie’, that’s still not released from Debian, let alone Raspbian. Have you tried reverting to ‘wheezy’?
Chris M
I still get the error even after a new install. How can I fix this? Or is there even a fix?
I need some packaged to install my Afafruti LCD 16x2 with 5 buttons to let it show the current playing song and use the buttons for forward, back etc. I’m using ]this instructables – https://aubreykloppers.wordpress.com/2014/01/30/raspberry-pi-volumio-a-new-music-player-and-it-works-out-the-box/
But it won’t install line:
apt-get update;apt-get install git python-smbus i2c-tools python-dev python-rpi.gpio
Is there a workaround or does anybody else know a different way to install the correct packages.
Jeroen
Get:5 http://mirrordirector.raspbian.org jessie/main armhf Packages [8962 kB]
Get:6 http://mirrordirector.raspbian.org wheezy/main Sources [6072 kB]
Fetched 15.1 MB in 58s (256 kB/s)
Hey Guys, sadly I have the same problem. First it all worked fine. Then I messed up the SD card (power blackout), re flashed it and since then I cant update. Changing jessy in to wheezy does not work for me sadly
Hope somebody can help!!
nrsz
February 26, 2015, 12:18pm
11
same here:
Err repo.volumio.org jessie/main armhf Packages
Err repo.volumio.org jessie/contrib armhf Packages
Ign repo.volumio.org jessie/contrib Translation-en_GB
Ign repo.volumio.org jessie/main Translation-en_GB
W: Failed to fetch repo.volumio.org/apt/dists/jessi … f/Packages 500 Internal Server Error
