I just had some trouble trying to install Volumio on a 4GB SD Card (to free up my working 8GB card for the new Pi 3+ I have on order).
Using balenaEtcher the resultant card didn’t work.
However, after a bit of experimenting, I put the card back in the PC and used GParted and resized the partitions to approx 1.5 GB for Volumio and 2.5 for volumio_data and it is appears to be running fine.
I also modified the GPU memory entry to 16MB (since my Pi is a 256)
I am seeking advice as to whether these choices are sensible, (i.e. is the thing likely to keel over next time there’s an update?)
There are different 4 GB Cards, may be thats the Problem. 4 GB can be a real SDcard and SDHC Format. I have had a Navigation System, that didn’t like the SDHC and it was not so easy to find normal SDcards in that Size.
Save yourself the trouble and buy a 8, or better even 16 Gb card. They cost €10 or so. And while you’re at it, pick one that it compatible with Raspberry Pi.
The problem is also with larger cards. My 8 and 16 also had a problem. This is not about the card, but about the fact that after installation and launch volumio does not extend the partition for the remaining free space.
