3rd partition does not resize on Odroid C1+
While trying to install the touch display, my Volumio install went bust. While looking at the partition table of my emmc module, I noticed that the last partition was only ~400MB in size and was full.
I managed to grow the partition by hand with fdisk and resize2fs.
When the volumio install “goes bust” you end up with a undefined situation, so it is very well possible that the 3rd partition will not get resized if the indicator is missing in the boot partition.
We would need more info in order to help you.
How did you get the volumio install to go bust and how did you manage to get it back on the rails again?
Thanks for replying. My install has gone bust while I was installing the touch display driver. I saw it installed a lot of X.org packages, and Chromium. Then it goes bust and Volumio didn’t work anymore - by this I mean it even refused to boot.
I solved the problem by “extending” the 3rd partition with fdisk+resize2fs. However, I can provide some help next week I hope.
