Dears, installed the lates update, everything seems to work, anything you look for let me know.
Current setup (test kit):
Pi5, Kali, I2S connected AK 4495 DAC trough IL715 isolators to seperate the ground from the Pi.
Needed to set resample in order to feed the dac with 24 bit, as 16 bit did not produce output. Using audiophonics ES9028 config.
I use it too ( it was one way to start my Waveshare with Pi5 ).
No issues. USB - Xmos - PCM63 DAC plays all source in all depth.
Hi!
How to (easy) check changelogs on what is changed since 3.569 (latest release) in this 3.854 version, before updating?
sudo apt update, sudo apt upgrade?
don’t do it !! you can destroy your copy of Volumio
Not an answer to the topic, i just did the apt update and upgrade and still runs fine.
DON’T/NEVER run sudo apt upgrade. It will break the OS
Not if you are not playing around and not ready to reflash. Its my test thing and even has peppy on it. Trying to see how much it can take before reflash! For a test version I am quite impressed!
How to acquire this alpha build for RPi? Any link to download?
Just turn on test mode and do an auto update.
