lsmod.txt
Module Size Used by
vc4 360448 2
snd_soc_hdmi_codec 16384 1
drm_display_helper 16384 1 vc4
cec 45056 1 vc4
drm_dma_helper 20480 2 vc4
drm_kms_helper 192512 2 drm_dma_helper,vc4
drm 593920 5 drm_dma_helper,vc4,drm_display_helper,drm_kms_helper
drm_panel_orientation_quirks 12288 1 drm
snd_soc_core 266240 2 vc4,snd_soc_hdmi_codec
snd_compress 16384 1 snd_soc_core
snd_pcm_dmaengine 16384 1 snd_soc_core
cmac 12288 1
bnep 16384 2
nft_chain_nat 12288 4
xt_REDIRECT 12288 1
nf_nat 49152 2 nft_chain_nat,xt_REDIRECT
nf_conntrack 143360 2 xt_REDIRECT,nf_nat
nf_defrag_ipv6 16384 1 nf_conntrack
nf_defrag_ipv4 12288 1 nf_conntrack
xt_tcpudp 12288 1
nft_compat 16384 2
nf_tables 249856 5 nft_compat,nft_chain_nat
nfnetlink 20480 2 nft_compat,nf_tables
8021q 28672 0
garp 12288 1 8021q
stp 12288 1 garp
llc 12288 2 garp,stp
joydev 16384 0
snd_usb_audio 278528 1
snd_hwdep 12288 1 snd_usb_audio
brcmfmac_wcc 12288 0
snd_usbmidi_lib 28672 1 snd_usb_audio
snd_seq_midi 12288 0
snd_seq_midi_event 12288 1 snd_seq_midi
brcmfmac 356352 1 brcmfmac_wcc
raspberrypi_ts 12288 0
snd_rawmidi 32768 2 snd_seq_midi,snd_usbmidi_lib
hci_uart 40960 0
btbcm 20480 1 hci_uart
raspberrypi_hwmon 12288 0
bluetooth 544768 24 hci_uart,bnep,btbcm
brcmutil 16384 1 brcmfmac
snd_bcm2835 24576 2
snd_pcm 126976 6 snd_compress,snd_usb_audio,snd_pcm_dmaengine,snd_soc_hdmi_codec,snd_bcm2835,snd_soc_core
cfg80211 872448 1 brcmfmac
bcm2835_codec 49152 0
bcm2835_v4l2 45056 0
snd_seq 73728 2 snd_seq_midi_event,snd_seq_midi
snd_seq_device 12288 3 snd_seq,snd_rawmidi,snd_seq_midi
videobuf2_vmalloc 12288 1 bcm2835_v4l2
snd_timer 32768 2 snd_seq,snd_pcm
bcm2835_isp 28672 0
ecdh_generic 12288 2 bluetooth
ecc 40960 1 ecdh_generic
v4l2_mem2mem 36864 1 bcm2835_codec
bcm2835_mmal_vchiq 32768 3 bcm2835_isp,bcm2835_codec,bcm2835_v4l2
rfkill 28672 5 bluetooth,cfg80211
snd 94208 18 snd_compress,snd_hwdep,snd_seq,snd_usb_audio,snd_soc_hdmi_codec,snd_timer,snd_rawmidi,snd_usbmidi_lib,snd_seq_device,snd_bcm2835,snd_soc_core,snd_pcm
videobuf2_dma_contig 16384 2 bcm2835_isp,bcm2835_codec
videobuf2_memops 12288 2 videobuf2_dma_contig,videobuf2_vmalloc
videobuf2_v4l2 28672 4 bcm2835_isp,bcm2835_codec,bcm2835_v4l2,v4l2_mem2mem
videodev 286720 5 bcm2835_isp,bcm2835_codec,bcm2835_v4l2,v4l2_mem2mem,videobuf2_v4l2
raspberrypi_gpiomem 12288 0
videobuf2_common 65536 8 bcm2835_isp,bcm2835_codec,videobuf2_dma_contig,videobuf2_vmalloc,videobuf2_memops,bcm2835_v4l2,v4l2_mem2mem,videobuf2_v4l2
vc_sm_cma 32768 2 bcm2835_isp,bcm2835_mmal_vchiq
mc 53248 7 bcm2835_isp,bcm2835_codec,snd_usb_audio,videobuf2_common,videodev,v4l2_mem2mem,videobuf2_v4l2
rpi_backlight 12288 0
backlight 16384 3 rpi_backlight,drm_kms_helper,drm
uio_pdrv_genirq 12288 0
uio 20480 1 uio_pdrv_genirq
i2c_dev 12288 0
ip_tables 28672 0
x_tables 32768 4 ip_tables,nft_compat,xt_tcpudp,xt_REDIRECT
ipv6 528384 72
uas 24576 0
squashfs 49152 1
overlay 135168 1
nls_iso8859_1 12288 0
fuse 135168 1
i2c_bcm2835 12288 0
fixed 12288 0
dmesg.txt
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 6.6.56-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1803 SMP Thu Oct 10 14:08:55 BST 2024
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
[ 0.000000] random: crng init done
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x34000000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x34000000…0x37ffffff (65536 KiB) map reusable linux,cma
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x0000000037ffffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000037ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000037ffffff]
[ 0.000000] percpu: Embedded 18 pages/cpu s41812 r8192 d23724 u73728
[ 0.000000] pcpu-alloc: s41812 r8192 d23724 u73728 alloc=18*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=800 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 splash plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 quiet console=ttyS0,115200 console=tty1 imgpart=UUID=ed280c2b-b4b4-43e6-87d7-b67377eacab2 imgfile=/volumio_current.sqsh bootpart=UUID=FCA2-3F9A datapart=UUID=0367e456-8c2f-458a-8465-47f124ad9fdd uuidconfig=cmdline.txt pcie_aspm=off pci=pcie_bus_safe rootwait bootdelay=7 logo.nologo vt.global_cursor_default=0 net.ifnames=0 snd-bcm2835.enable_compat_alsa= snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 loglevel=0 nodebug use_kmsg=no
[ 0.000000] Unknown kernel command line parameters “splash nodebug imgpart=UUID=ed280c2b-b4b4-43e6-87d7-b67377eacab2 imgfile=/volumio_current.sqsh bootpart=UUID=FCA2-3F9A datapart=UUID=0367e456-8c2f-458a-8465-47f124ad9fdd uuidconfig=cmdline.txt pcie_aspm=off pci=pcie_bus_safe bootdelay=7 use_kmsg=no”, will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 227360
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 796008K/917504K available (11264K kernel code, 1476K rwdata, 3256K rodata, 1024K init, 606K bss, 55960K reserved, 65536K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 36450 entries in 107 pages
[ 0.000000] ftrace: allocated 107 pages with 5 groups
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000001] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000019] Switching to timer-based delay loop, resolution 52ns
[ 0.000409] Console: colour dummy device 80x30
[ 0.000427] printk: console [tty1] enabled
[ 0.000532] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=192000)
[ 0.000554] CPU: Testing write buffer coherency: ok
[ 0.000609] pid_max: default: 32768 minimum: 301
[ 0.000723] LSM: initializing lsm=capability,integrity
[ 0.000917] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.000939] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001976] cgroup: Disabling memory control group subsystem
[ 0.002543] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.003544] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[ 0.003643] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[ 0.003796] Setting up static identity map for 0x100000 - 0x10003c
[ 0.003944] rcu: Hierarchical SRCU implementation.
[ 0.003953] rcu: Max phase no-delay instances is 1000.
[ 0.004639] smp: Bringing up secondary CPUs …
[ 0.005538] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.006438] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.007262] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.007369] smp: Brought up 1 node, 4 CPUs
[ 0.007390] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.007404] CPU: All CPU(s) started in HYP mode.
[ 0.007411] CPU: Virtualization extensions available.
[ 0.008550] devtmpfs: initialized
[ 0.021625] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.021840] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.021868] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.024279] pinctrl core: initialized pinctrl subsystem
[ 0.025282] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.027817] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.033308] audit: initializing netlink subsys (disabled)
[ 0.033550] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
[ 0.034111] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.034672] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.034689] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.035013] Serial: AMBA PL011 UART driver
[ 0.039359] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.060031] raspberrypi-firmware soc:firmware: Attached to firmware from 2024-09-13T16:00:01, variant start
[ 0.070044] raspberrypi-firmware soc:firmware: Firmware hash is ddfba3e3c234500025b545512b4b214f28e453e9
[ 0.084455] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.087091] bcm2835-dma 3f007000.dma-controller: DMA legacy API manager, dmachans=0x1
[ 0.088759] SCSI subsystem initialized
[ 0.088995] usbcore: registered new interface driver usbfs
[ 0.089044] usbcore: registered new interface driver hub
[ 0.089096] usbcore: registered new device driver usb
[ 0.089493] pps_core: LinuxPPS API ver. 1 registered
[ 0.089503] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.089529] PTP clock support registered
[ 0.091534] clocksource: Switched to clocksource arch_sys_counter
[ 0.091973] VFS: Disk quotas dquot_6.6.0
[ 0.092027] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.092154] FS-Cache: Loaded
[ 0.096394] CacheFiles: Loaded
[ 0.105769] NET: Registered PF_INET protocol family
[ 0.106047] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.108560] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.108596] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.108617] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.108730] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.109058] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.109188] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.109242] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.109440] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.109939] RPC: Registered named UNIX socket transport module.
[ 0.109951] RPC: Registered udp transport module.
[ 0.109959] RPC: Registered tcp transport module.
[ 0.109966] RPC: Registered tcp-with-tls transport module.
[ 0.109973] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.110790] Trying to unpack rootfs image as initramfs…
[ 0.131947] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 1.427545] Freeing initrd memory: 28068K
[ 2.060401] Initialise system trusted keyrings
[ 2.060706] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 2.060780] zbud: loaded
[ 2.061601] NFS: Registering the id_resolver key type
[ 2.061632] Key type id_resolver registered
[ 2.061641] Key type id_legacy registered
[ 2.061673] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 2.061684] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 2.062427] Key type asymmetric registered
[ 2.062439] Asymmetric key parser ‘x509’ registered
[ 2.062514] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 2.062528] io scheduler mq-deadline registered
[ 2.062538] io scheduler kyber registered
[ 2.062590] io scheduler bfq registered
[ 2.064471] pinctrl-bcm2835 3f200000.gpio: GPIO_OUT persistence: yes
[ 2.067125] bcm2708_fb soc:fb: FB found 1 display(s)
[ 2.074698] Console: switching to colour frame buffer device 100x30
[ 2.079720] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 800x480
[ 2.083795] bcm2835-rng 3f104000.rng: hwrng registered
[ 2.084108] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 2.095728] brd: module loaded
[ 2.103140] loop: module loaded
[ 2.103735] Loading iSCSI transport class v2.0-870.
[ 2.105209] usbcore: registered new interface driver lan78xx
[ 2.105256] usbcore: registered new interface driver smsc95xx
[ 2.105268] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.833338] Core Release: 2.80a
[ 2.833360] Setting default values for core params
[ 2.833386] Finished setting default values for core params
[ 3.033658] Using Buffer DMA mode
[ 3.033667] Periodic Transfer Interrupt Enhancement - disabled
[ 3.033675] Multiprocessor Interrupt Enhancement - disabled
[ 3.033683] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.033722] Dedicated Tx FIFOs mode
[ 3.034222] WARN::dwc_otg_hcd_init:1070: FIQ DMA bounce buffers: virt = b4104000 dma = 0xf4104000 len=9024
[ 3.034261] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 3.034276] dwc_otg: Microframe scheduler enabled
[ 3.034385] WARN::hcd_init_fiq:457: FIQ on core 1
[ 3.034404] WARN::hcd_init_fiq:458: FIQ ASM at 80887df0 length 36
[ 3.034425] WARN::hcd_init_fiq:496: MPHI regs_base at b8810000
[ 3.034449] dwc_otg 3f980000.usb: DWC OTG Controller
[ 3.034501] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 3.034539] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
[ 3.034592] Init: Port Power? op_state=1
[ 3.034600] Init: Power Port (0)
[ 3.034805] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[ 3.034824] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.034839] usb usb1: Product: DWC OTG Controller
[ 3.034850] usb usb1: Manufacturer: Linux 6.6.56-v7+ dwc_otg_hcd
[ 3.034861] usb usb1: SerialNumber: 3f980000.usb
[ 3.035508] hub 1-0:1.0: USB hub found
[ 3.035552] hub 1-0:1.0: 1 port detected
[ 3.036164] dwc_otg: FIQ enabled
[ 3.036173] dwc_otg: NAK holdoff enabled
[ 3.036180] dwc_otg: FIQ split-transaction FSM enabled
[ 3.036195] Module dwc_common_port init
[ 3.036451] usbcore: registered new interface driver usb-storage
[ 3.036653] mousedev: PS/2 mouse device common for all mice
[ 3.038799] sdhci: Secure Digital Host Controller Interface driver
[ 3.038810] sdhci: Copyright(c) Pierre Ossman
[ 3.039018] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.040815] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.041225] hid: raw HID events driver (C) Jiri Kosina
[ 3.041333] usbcore: registered new interface driver usbhid
[ 3.041344] usbhid: USB HID core driver
[ 3.045956] Initializing XFRM netlink socket
[ 3.046014] NET: Registered PF_PACKET protocol family
[ 3.046117] Key type dns_resolver registered
[ 3.046636] Registering SWP/SWPB emulation handler
[ 3.078319] registered taskstats version 1
[ 3.078545] Loading compiled-in X.509 certificates
[ 3.090959] Key type .fscrypt registered
[ 3.090982] Key type fscrypt-provisioning registered
[ 3.099346] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 3.099828] 3f201000.serial: ttyAMA1 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
[ 3.100174] serial serial0: tty port ttyAMA1 registered
[ 3.103198] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 3.103481] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 3.104709] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 3.104726] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ 3.132531] sdhost: log_buf @ 148efa27 (f4107000)
[ 3.161652] Indeed it is in host mode hprt0 = 00021501
[ 3.185527] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 3.187927] of_cfs_init
[ 3.188060] of_cfs_init: OK
[ 3.188464] clk: Disabling unused clocks
[ 3.218741] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.222160] mmc0: Host Software Queue enabled
[ 3.222184] mmc0: new high speed SDHC card at address 0007
[ 3.223189] mmcblk0: mmc0:0007 SD4GB 3.71 GiB
[ 3.223734] Freeing unused kernel image (initmem) memory: 1024K
[ 3.224336] Run /init as init process
[ 3.224346] with arguments:
[ 3.224352] /init
[ 3.224358] splash
[ 3.224364] nodebug
[ 3.224371] with environment:
[ 3.224377] HOME=/
[ 3.224383] TERM=linux
[ 3.224389] imgpart=UUID=ed280c2b-b4b4-43e6-87d7-b67377eacab2
[ 3.224397] imgfile=/volumio_current.sqsh
[ 3.224404] bootpart=UUID=FCA2-3F9A
[ 3.224411] datapart=UUID=0367e456-8c2f-458a-8465-47f124ad9fdd
[ 3.224418] uuidconfig=cmdline.txt
[ 3.224425] pcie_aspm=off
[ 3.224431] pci=pcie_bus_safe
[ 3.224438] bootdelay=7
[ 3.224444] use_kmsg=no
[ 3.226456] mmcblk0: p1 p2 p3
[ 3.227262] mmcblk0: mmc0:0007 SD4GB 3.71 GiB
[ 3.327733] mmc1: new high speed SDIO card at address 0001
[ 3.391612] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 3.391797] Indeed it is in host mode hprt0 = 00001101
[ 3.651905] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
[ 3.651942] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.652967] hub 1-1:1.0: USB hub found
[ 3.653084] hub 1-1:1.0: 5 ports detected
[ 3.971616] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 4.119166] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[ 4.119206] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.122424] smsc95xx v2.0.0
[ 4.265622] SMSC LAN8700 usb-001:003:01: attached PHY driver (mii_bus:phy_addr=usb-001:003:01, irq=199)
[ 4.266488] smsc95xx 1-1.1:1.0 eth0: register ‘smsc95xx’ at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:2e:fc:d2
[ 4.273648] fuse: init (API version 7.39)
[ 4.361789] usb 1-1.4: new high-speed USB device number 4 using dwc_otg
[ 4.455627] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 4.496996] usbcore: registered new interface driver uas
[ 4.521876] usb 1-1.4: New USB device found, idVendor=0d8c, idProduct=0004, bcdDevice= 2.08
[ 4.521935] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.521968] usb 1-1.4: Product: USB2.0 High-Speed True HD Audio
[ 4.521991] usb 1-1.4: Manufacturer: C-Media Electronics Inc.
[ 4.548619] input: C-Media Electronics Inc. USB2.0 High-Speed True HD Audio as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.2/0003:0D8C:0004.0001/input/input0
[ 4.612139] hid-generic 0003:0D8C:0004.0001: input,hidraw0: USB HID v1.00 Device [C-Media Electronics Inc. USB2.0 High-Speed True HD Audio] on usb-3f980000.usb-1.4/input2
[ 12.394998] EXT4-fs (mmcblk0p2): mounted filesystem ed280c2b-b4b4-43e6-87d7-b67377eacab2 r/w with ordered data mode. Quota mode: none.
[ 46.057211] loop0: detected capacity change from 0 to 994880
[ 46.269589] EXT4-fs (mmcblk0p3): mounted filesystem 0367e456-8c2f-458a-8465-47f124ad9fdd r/w with ordered data mode. Quota mode: none.
[ 47.805845] systemd[1]: System time before build time, advancing clock.
[ 48.074079] NET: Registered PF_INET6 protocol family
[ 48.075531] Segment Routing with IPv6
[ 48.075578] In-situ OAM (IOAM) with IPv6
[ 48.266538] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 48.270875] systemd[1]: Detected architecture arm.
[ 48.368182] systemd[1]: Set hostname to .
[ 49.249502] systemd[1]: /lib/systemd/system/winbind.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/winbindd.pid \xe2\x86\x92 /run/samba/winbindd.pid; please update the unit file accordingly.
[ 49.563057] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 49.564432] systemd[1]: Listening on udev Control Socket.
[ 49.564873] systemd[1]: Listening on udev Kernel Socket.
[ 49.565822] systemd[1]: Listening on Journal Audit Socket.
[ 49.674008] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 49.675225] systemd[1]: Listening on Journal Socket.
[ 50.231929] i2c_dev: i2c /dev entries driver
[ 52.796806] systemd-journald[336]: Received request to flush runtime journal from PID 1
[ 53.257800] mc: Linux media interface: v0.10
[ 53.269646] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 53.271198] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 53.271239] [vc_sm_connected_init]: start
[ 53.276880] [vc_sm_connected_init]: installed successfully
[ 53.331828] rpi-gpiomem 3f200000.gpiomem: window base 0x3f200000 size 0x00001000
[ 53.332262] rpi-gpiomem 3f200000.gpiomem: initialised 1 regions as /dev/gpiomem
[ 53.516698] videodev: Linux video capture interface: v2.00
[ 53.624853] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 53.760342] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 53.801986] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 53.811748] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 53.816408] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 53.821769] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 53.821819] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 53.821855] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 53.821872] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 53.821887] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 53.835101] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 53.835618] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 53.836017] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 53.836340] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 53.836371] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 53.836392] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 53.836408] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 53.836423] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 53.836632] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 54.135126] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 54.140146] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 54.208845] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 54.208901] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 54.214334] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 54.224186] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 54.224243] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 54.258114] Loaded X.509 cert ‘benh@debian.org: 577e021cb980e0e820821ba7b54b4961b8b4fadf’
[ 54.260776] Loaded X.509 cert ‘romain.perier@gmail.com: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328’
[ 54.282335] Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 54.285130] Loaded X.509 cert ‘wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600’
[ 54.286726] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 54.286780] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 54.291220] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 54.291279] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 54.294683] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 54.294751] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 54.311487] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 54.312797] snd_bcm2835: unknown parameter ‘enable_compat_alsa’ ignored
[ 54.328996] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 54.357362] Bluetooth: Core ver 2.22
[ 54.357832] NET: Registered PF_BLUETOOTH protocol family
[ 54.357886] Bluetooth: HCI device and connection manager initialized
[ 54.391630] Bluetooth: HCI socket layer initialized
[ 54.391682] Bluetooth: L2CAP socket layer initialized
[ 54.391729] Bluetooth: SCO socket layer initialized
[ 54.568684] Bluetooth: HCI UART driver ver 2.3
[ 54.568718] Bluetooth: HCI UART protocol H4 registered
[ 54.568830] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 54.570183] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
[ 54.570467] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
[ 54.619275] Bluetooth: HCI UART protocol Broadcom registered
[ 54.678227] input: raspberrypi-ts as /devices/platform/soc/soc:firmware/soc:firmware:touchscreen/input/input1
[ 54.681852] uart-pl011 3f201000.serial: no DMA platform data
[ 54.835478] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[ 54.842113] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 54.846693] usbcore: registered new interface driver brcmfmac
[ 54.950086] Bluetooth: hci0: BCM: chip id 94
[ 54.950648] Bluetooth: hci0: BCM: features 0x2e
[ 54.954199] Bluetooth: hci0: BCM43430A1
[ 54.954277] Bluetooth: hci0: BCM43430A1 (001.002.009) build 0000
[ 54.988461] Bluetooth: hci0: BCM43430A1 ‘brcm/BCM43430A1.hcd’ Patch
[ 55.204316] brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2)
[ 55.205536] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Jul 19 2021 03:24:18 version 7.45.98 (TOB) (56df937 CY) FWID 01-8e14b897
[ 55.640913] usbcore: registered new interface driver snd-usb-audio
[ 55.912854] Bluetooth: hci0: BCM: features 0x2e
[ 55.916093] Bluetooth: hci0: BCM43438A1 37.4MHz Raspberry Pi 3-0141
[ 55.916132] Bluetooth: hci0: BCM43430A1 (001.002.009) build 0508
[ 56.930537] alsactl[534]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[ 58.006863] warning: `iwconfig’ uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
[ 58.024224] 8021q: 802.1Q VLAN Support v1.8
[ 58.138187] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save disabled
[ 58.315108] smsc95xx 1-1.1:1.0 eth0: hardware isn’t capable of remote wakeup
[ 58.318054] smsc95xx 1-1.1:1.0 eth0: Link is Up - 100Mbps/Full - flow control off
[ 61.983294] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 61.983322] Bluetooth: BNEP filters: protocol multicast
[ 61.983342] Bluetooth: BNEP socket layer initialized
[ 61.991016] Bluetooth: MGMT ver 1.22
[ 64.823136] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save disabled
[ 67.264777] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save disabled
[ 86.020926] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save disabled
[ 87.411750] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save disabled
[ 450.302222] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /reserved-memory/linux,cma/size
[ 450.302255] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/i2c@7e805000/status
[ 450.302267] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/fb/status
[ 450.302279] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/pixelvalve@7e206000/status
[ 450.302290] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/pixelvalve@7e207000/status
[ 450.302301] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/pixelvalve@7e807000/status
[ 450.302314] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/hvs@7e400000/status
[ 450.302327] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/hdmi@7e902000/status
[ 450.302338] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/v3d@7ec00000/status
[ 450.302349] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/gpu/status
[ 450.302361] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/cprman@7e101000/claim-clocks
[ 450.302375] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/txp@7e004000/status
[ 450.302387] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /chosen/bootargs
[ 450.303938] Console: switching to colour dummy device 80x30
[ 450.730180] vc4-drm soc:gpu: bound 3f400000.hvs (ops vc4_hvs_ops [vc4])
[ 450.731606] Registered IR keymap rc-cec
[ 450.731779] rc rc0: vc4-hdmi as /devices/platform/soc/3f902000.hdmi/rc/rc0
[ 450.733236] input: vc4-hdmi as /devices/platform/soc/3f902000.hdmi/rc/rc0/input2
[ 450.738440] input: vc4-hdmi HDMI Jack as /devices/platform/soc/3f902000.hdmi/sound/card1/input3
[ 450.741902] vc4-drm soc:gpu: bound 3f902000.hdmi (ops vc4_hdmi_ops [vc4])
[ 450.742363] vc4-drm soc:gpu: bound 3f004000.txp (ops vc4_txp_ops [vc4])
[ 450.742676] vc4-drm soc:gpu: bound 3f206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 450.742951] vc4-drm soc:gpu: bound 3f207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 450.743171] vc4-drm soc:gpu: bound 3f807000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 450.743341] vc4-drm soc:gpu: bound 3fc00000.v3d (ops vc4_v3d_ops [vc4])
[ 450.747838] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 0
[ 450.748818] vc4-drm soc:gpu: [drm] Cannot find any crtc or sizes
[ 450.749777] vc4-drm soc:gpu: [drm] Cannot find any crtc or sizes
[ 460.627247] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/i2c0mux/i2c@1/status
[ 460.627299] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/dsi@7e700000/status
[ 460.627407] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/i2c0mux/i2c@1/status
[ 460.627429] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/i2c@7e205000/status
[ 460.627441] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/i2c0mux/status
[ 460.627468] OF: overlay: ERROR: multiple fragments add, update, and/or delete property /soc/i2c0mux/i2c@1/status
