3.5" Hosyond 3.5" display shows software rev 4.1.0.3 then goes blank unless touch plugin is uninstalled
Hosyond 3.5" tft display shows software rev 4.1.0.3 then goes blank unless touch plugin rev 3.6.0 is uninstalled. When uninstall of plugin starts the display shows the login screen that you see normally from HDMI port. the Volumio OS is installed on a RPI 3B+. I have tried many diffenent instructions to install the display but the instructions below are the ones that are currently loaded on a fresh image.
  1. Install Volumio as usual by buring image to micro SD . I will not go through detail here as you can see it from Volumio Official Site.
  2. Turn on raspberry PI and configure Wireless if you use it.
  3. Open volumio.local in browser and install Plugin Touch Display and Enable Plugin.
    To configure volumio , we will use SSH and remote to volumio. We have to enable SSH by browsing URL http://volumio.local/dev and click
  4. Enable SSH .
    connect to volumio.local user name :volumio@volumio.local and password :volumio
  5. When login to volumio you will see the prompt volumio@volumio:$ and current directory is /home/volumio
  6. Enter this command line by line with Enter.
git clone GitHub - goodtft/LCD-show: 2.4" 2.8"3.2" 3.5" 5.0" 7.0" TFT LCD driver for the Raspberry PI 3B+/A/A+/B/B+/PI2/ PI3/ZERO/ZERO W · GitHub
cd LCD-show
cd usr
  1. Enter following command
sudo mkdir -p /etc/X11/xorg.conf.d
sudo cp tft35a-overlay.dtb /boot/overlays/tft35a.dtbo
sudo cp -rf 99-calibration.conf-35–90 /etc/X11/xorg.conf.d/99- calibration.conf
sudo mkdir -p /usr/share/X11/xorg.conf.d/
sudo cp -rf ./99-fbturbo.conf /usr/share/X11/xorg.conf.d/99-fbturbo.conf
  1. sudo nano /boot/config.txt
    enter these lines to the config.txt file before the include userconfig.txt line
dtparam=spi=on
dtoverlay=tft35a:rotate=90
  1. sudo sed ‘s/”fbturbo”/”fbdev”/’ -i /usr/share/X11/xorg.conf.d/99-fbturbo.conf
Just a little more detail to the problem. The display seems to be working although I have not tested the touch screen a all. With the Touch Display plugin installed the screen is blank except for showing the software rev for 30-60 sec on boot. If I uninstall the plugin the screen shows the login page and I am able to login using a usb keyboard. I hope someone out their can help me finish the set up and get the Volumio screen the load. Your help is much apprciated.
I gave up on trying to install the Hosyond 3.5" display in the Volumio os and tried installing it on multiple Raspbian OS without much luck. I did find a Raspbian OS download at the Hosyond support site that already had the driver and calibration software. This is the link for the download https://www.dropbox.com/scl/fo/s2tb9ev56u2fsv4jq3w26/AGT5DS5xjeFVB1HICNMO838/Raspbian%20Image%20for%20Pi3?dl=0&e=1&rlkey=0ugrwzx8e0iqwfv1iimu6gb54&subfolder_nav_tracking=1
When I booted up the downloaded software the only problem was the display resolution was not correct. I have to see if I can change it to 320x480 which is not an option in the display set up.
