Running v3.179 on a Pi Zero W2 and logged in with a free level account.
But when I try to access the plugin store, it tells me I can’t access it unless I log in?
See the screenshot below, you can see I’m logged in but got the message.
Tried to log out and back in again and didn’t help. This was working in an earlier version of v3 as I do have a couple of plugins installed from the store but something’s gone wrong on at least the current version.
Any suggestions on how to fix it up and regain access, or is it one to just wipe and reinstall? Can provide logs if needed (and if guided on how to do so).
This is weird indeed.
Would you share some system logs please?
Preferable from a fresh reboot, with minimal steps to reproduce the problem
Note though, we have Christmas Season, so support slowed down a bit…
Booted up, opened the web GUI and selected the plugins tab (and got the log in request pop-up).
The system info and music service shield were installed before via the store, and the pirate audio phat one was a manual install. Maybe it’s the latter that’s screwed things up somehow?
All three plugins are working fine in themselves, it’s just the store access that’s gone weird.
Had a bit of a play with this, and it seems to be related to using a Pi Zero W2.
I switched the SD card and the Pirate Audio Hat over to a Pi Zero W (an old v1 one) and when it booted up, I was logged out of My Volumio. Logged in there and the plugin store worked fine.
When I get a bit more time I’ll switch it back to the Zero W2 and see if the problem recurs or not. But another hint perhaps anyway?
Yes, the pirate audio one is a manual install (as I said in the first post ).
It’s just a bit weird why it works on the zero but not the zero 2. No problem to rebuild it (once the pirate audio plugin gets properly released - from my understanding it’s submitted now, the version I’m running is that final version).
Thought it worth reporting anyway as it was strange to be asked to log in when I was already logged in.
