2nd screen - AUDIOPHONICS EVO-SABRE PACK DIY Balanced DAC 2xES9038Q2M
Is there a Plugin to enable my DACs second screen? I have seen recommendations to program it to work, but I’m not that computer knowledgeable.
Second 3.12 "256x64 OLED screen
plugin is still beta status, but works like a charme
includes second screen, remote, etc.
because it’s in beta you have to do this instruction
https://github.com/audiophonics/Evo_Sabre_Volumio3/
Hi Judydudi,
Thanks for the reply. I’ve got as far as opening up the SSH box via Putty, but before I can enter the script, it says Network Error - Timed out.
This is some pretty involved stuff here!
Thanks for your help and advice.
Sincerely,
Bob
judidudi,
I got it going. Thank you!
Judydudi,
Can you advise me on how to set the correct time on the second 3.12 "256x64 OLED screen?
Bob
hi bob
i try. i belive it’s the timezone change you need.
  1. connect via ssh
    SSH - Volumio Documentation
and 2. change time zone, reboot
sudo dpkg-reconfigure tzdata
reboot
  1. disable ssh
good luck!
