UDOO
I can’t make the UDOO play hires files. When started the Playback page shows the file is playing but there is not sound. Also, when hitting F5 to refresh the browser the time indicator jumps approximately 10 seconds ahead every time I use F5.
RPI
Here the exact same sound file plays just fine.
DAC used
Hegel HD2
EXPERIMENTATIONS
I tried to add the “options snd-usb-audio nrpacks=1” as described in a different post.
SUGGESTIONS
Does anyone have a suggestion to what I can try to make the UDOO play hires files?
I have little knowledge about linux and need a step by step guide for monkeys if I should change anything using SSH.
Thanks and hoping for your suggestions
