24 / 192 Tidal problem
Hi, all 24/192, I’m waiting for a solution from volumio support. Tell me if you have Buffer Before Play and what the Audio Buffer Size is.
good equipment this IAN CANADA
I have this setting
It’s strange that Tidal shows this album in 16/44.1 on what you showed, on my RPI and phone it shows 24/194
When I go to the HiRes folder, it’s max 24/96 like Tidal and Volumio
I have yes
I only have a problem with 24/192, not 24/96
24/192 plays fine for me! I have it tuned with TIDAL to Volumium Ps: I had a lower quality set in the Tidal application…
:+1:
I will wait for the answer from volumio support , thank you for your interest
there is still no solution, I have such a card
Does that old Tech actually sound any better and USB? Digital is digital. Have you done a blind test?
I used to use toslink and coax but it’s not always better and can’t handle hi-res. I’m sure it is nice, I used to have sound blaster sound cards but now have a DAC.
